Wint winamp, I am not able to create a playlist containing songs from bot , (external and internal) memories, you can only use song from the same memory. can media monkey or other organizer do that? can be done at all?
Winamp only creates .m3u format playlists (at least in MSC mode), and this format does not support files from both memory locations.
If you want to include music located in both the player’s internal memory and the external card, you can convert the .m3u playlists to .pla format. This type of playlist will play songs from either source. There are programs/scripts people have writen to do this. Google should find some for you.
If you want to include music located in both the player's internal memory and the external card, you can convert the .m3u playlists to .pla format. This type of playlist will play songs from either source. There are programs/scripts people have written to do this. Google should find some for you. |
