Does anyone use this program? I’m trying to create a playlist for my 8gb Fuze with no luck.
Here’s my process: I hook up my Fuze to the computer, add the files from my Fuze into the software, create a playlist, save the playlist back to the music folder of my Fuze.
The playlist shows up on the Fuze, but shows as empty. What am I missing? Thanks for the help
Make sure you have it set to output relative paths !(file:///C:/DOCUME%7E1/TIMMAR%7E1/LOCALS%7E1/Temp/moz-screenshot.jpg) !(file:///C:/DOCUME%7E1/TIMMAR%7E1/LOCALS%7E1/Temp/moz-screenshot-1.jpg)
Message Edited by tmarkoski on 10-21-2008 06:49 AM
Oops…dumb error on my part. I created a folder within my music folder to save it to, when all I needed to do was just save it to the music folder directly. Thanks for the help!
I had a similar problem renaming the album art files. Cut the file off the player and paste it onto your desktop. Rename it then cut it and paste it back on the player.
