When I open photos on my passport ultra it opens them in windows photo viewer. How do I change it so it opens in photoshop cs6.
Regards,
George
Regards,
George
Hi right click the picture file, Choose open with next window will give you an option to select choose default program in the next window you get a browse button click it and browse to the photoshop cs6 folder and choose the photoshop exe file that starts the program then make sure Always use the selected program to open this type of file is checked off and that’s it. This is called file associations if you have trouble a Google search for File Associations will also give you the same instructions.
Click the Kudos star to say thank you for helpful posts. And be sure to come back to click the ‘Accept as Solution’ button for the post that solved your issue.
