Pen Drive not supporting in android phone .
I recently formatted my 512 GB pen drive to NTFS . But as it was not supporting on my phone (android \poco x6 pro ) ,I reformatted it to fat32 file system . But the drive is still not showing on my phone .I tried to format it via many methods such as command prompt , APMEI Partition Manager , Windows File Explorer , EASEUS Partition Manager , but none worked . Can anyone suggest what I should do now ?
Looks like you’ve already tried multiple formatting methods, let’s rule out a few things.
  1. Does the pen drive show up on other Android devices? Maybe it’s a compatibility issue with your Poco X6 Pro.
  2. What happens when you plug it into a PC now? Does it show up normally in File Explorer, or does it have any errors in Disk Management?
  3. Did you format it using the correct sector size? Sometimes, FAT32 formatting can still mess up if the allocation unit size is too big/small.
Also, Android tends to prefer exFAT over FAT32 for larger drives. Have you tried formatting it to exFAT instead? That might just do the trick.
I tried 4 kb ,32 kb cluster size. Also other phones are not being able to read the pen drive
Can You suggest formatting details of exfat format
Perfectly fine with pc
