Just put a clean install of XP home edition on my Pc now when i to plug my fuze it wont install the drivers correctly. It says a problem occurred with installing the new hardware. When i go into the device manager it has a yellow question mark and says that its not working correctly, i have removed the drivers then tried it again with no luck. Where can i get the drivers from so my fuze will work.
They’re in Windows Media Player 10 & above. Check your version of WMP; XP came with Vers. 9 so you may need to update.
But if you just switch the USB mode to MSC on your Fuze, you shouldn’t have to even mess with all this falderall .
They're in Windows Media Player 10 & above. Check your version of WMP; XP came with Vers. 9 so you may need to update.
But if you just switch the USB mode to MSC on your Fuze, you shouldn't have to even mess with all this falderall. |
