Password Lockout Question
I ran across this on another site the poster had used wrong password (cap locks were on) and was locked out. An answer was to unplug and power off drive overnight. It worked then. Has anybody tried that ?
Joe
KB 3741:
“If you enter the wrong password 5 times, you will receive the screen below. In order to try your password 5 more times, you will need to safely eject the drive and unplug both the power and data cable from the unit. Then plug it back it. You will now be given 5 more tries”
I’m sure many people have tried it.
