Hi
i was told by the salesman that i could copy the windows 7 opperating system on to my passport essentials external hard drive, is this possible
thanx chris
Hi
thanx chris
The WD externals are not bootable. You could copy Windows but it wouldn’t be bootable. What are you trying to accomplish? There is software that will image your HD and you will be able to restore it if you have problems.
Joe
Hi
thank you for your reply, I dont know much about pc’s , i thought that if my pc crashed and i lost everything including windows that i would be able to put it back on the pc
chris:smiley:
Ok there are some free and paid programs that will do that. Paragon EaseUS and Macrium all have free programs that will do that. I use Acronis True Image paid. You burn a CD with these programs that is bootable and boot from that to restore. To be able to do incremental backups you need a paid version of all of these. I also partitioned my HD and Windows and programs are on one and my data is on the other. That way I can restore system without disturbing the data.
Joe
Hi joe
Thanx for your help
chris:smileyvery-happy:
