when i try to load on pc error message appears and wants me to send masseage to windows. if i try to load again i bright blue screen lights up telling me to try to load in safe mode. can any body help me please.
Thanks
Thanks
Sounds like same problem as “Passport Elite problem” post:
I had same problem. Easy fix, probably. Uninstall any Sonic or Roxio software. Those CD/DVD burners are not compatible with SmartWare and/or My Passport. If you have Windows XP or better, you can burn CDs without added software. If you want to burn DVDs you do need software. WD recommends Nero.
I got this info from the WD tech support line. You have 30 days free install support, give them a call if this doesn’t fix your BSOD.
Just bought a Passport Essential 640GB and gave me that BSOD. After reading the post here, I removed Roxio application and it is now working fine. WD should have included in their little pamphlet a warning that if you have a Roxio or Sonic software, you need to uninstall them. Thanks for the tip.
