I have a 1TB passport that won’t mount. the WD unlocker shows up on the desktop and allows me to enter the password but then nothing. I ran the disk utility and that said in red letters that i need to update the firmware but it also says back up what you can, I can’t back up anything. Is my data on the drive lost? or can i run the firmware update and might the data still be there?
Hello, it is possible that the files saved on the Passport are corrupted, with the help of a data recovery program you should be able to recover most of your files and then format the Passport to use it normally again. Using Google you can find several options.
