I Have 1TB WD My Book Essential…
Computer Spec:
2GB GT 430 Nvidia Card
4GB RAM
2.50 GHz E5200 Proccesor
Motherboard Foxconn G30/31 MK-V
I Have 6 Partitions
C:\
D:\
C and D are from Disk 0 Which Is 500 GB
But
G:\
H:\
I:\
J:\
These Four Are Of The WD 1TB My Book Essential
I Have Extremely Important Things On Them And I Don’t Want To Format It…
The Problem Is:
When I Open J:\ or I:\ … It Tells Me That It’s not accessible and could not perform reqeust because of an I/O Device Error ,
Please I Need Help And I Don’t Want To Format It …
Hello Mate,
Have you try with different cables, different computer? Are you getting the same results?
Yes I Tried Different Cables And Different Computers … same result … it became RAW and when i want to format it ,it 's write protected i tried many ways for format and recovery nothing worked i just want my files back.
You might try something like EaseUS Disk Wizard http://www.easeus.com/resource/repair-raw-disk.htm
Joe
Thanks Man , But I Already Tried It … Useless …
