I have the 1Tb WD external drive … I use it to record show from my DVR … the partition that has the recorded shows is telling me “location is not available … K:\HBPVR is not accessible. The file or directory is corrupted and unreadable.”
The partition with the commercial edited out can be access. What do I need to do?![]()
Corrupted partition means you will have to format the drive in order to use it again,.
Try formatting it on a computer and then connecting it to the DVR.
Ok … I will give that a try … thanks.
