I’m using WD 1TB hard disk only few times since last January, but when I tried to access it from different computers, all I get is “the parameter is incorrect” error. What does it mean? How to fix this without losing my data?
Hi atika,
Maybe you should try contacting WD’s Technical Support about this.
The link below will allow you to call support.
A few weeks ago I bought the My Cloud 3TB Cloud storage and everything seems fine and working but when I re start my laptop and the MyCloud Cloud loads again, I always get an error “The Parameter is Incorrect”.
However at the present time I don’t have the desktop device folder open and when I do open the device folder on my laptop all documents and the device is accessible.
Any help appreciated, why does it say Parameter is incorrect when the device restrts but I can then access the files on my laptop, everything works fie on my other mobile devices I get no error
Thanks
