When i dowload a book from my library with overdrive the book downloads as a song in the music file with each chapter as a seperate song. When i look at the clipzip in my computer using windows 7 pro the fiels are properly loaded in the book file. How can i fix thi?
Hi Jim, I have duplicated the issue on my end and the suggested step worked here.
Do all the files for each book have the same album tag? If they have the same album tag, and the track numbers are in the proper sequence, then I assume the book should probably play through in the correct order when playing the album, just like an album of songs does? I have never used Overdrive though.
