Outlook PST Splitter Tool to Split large PST
There are huge number of third party software available on internet but I provide you this brilliant outlook pst splitter software which helps avoids large PST corruption by dividing and categorizing them in smaller files. It uses its own PST splitter to avoid the risk of corruption of PST files due to the issue of being over-sized. It is fully capable of splitting all MS outlook item such as folders, contacts, calendars, journals, email folders. It avoids corruption in PST files and divides large-sized PST files into smaller files. It has wide range of advanced and well developed features to add more accuracy and efficiency in this software. It provide brilliant enhanced user friendly interface to make this process fast and simple. It supports all versions of MS Outlook like 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019.
If you have previously tried the manual method and there is no outcome then in such case, you can try Split PST Tool which is a quick software that helps to splits the large Outlook PST files into small PST files.
Divide PST by Date
Divide PST by Size
Divide PST by Year
Divide PST by Folder
Stellar Splitter for Outlook software allows users to work with all the versions of MS Outlook as well as Windows OS. By using this unique PST Splitter you can avoid the risk of corruption/damage of PST files. It is fully proficient in splitting all outlook items such as folders, contacts, calendars, email folders.
It has some feature like
  1. It has the trial version so that you can try it for an overview
  2. It has the capacity of splitting large PST without changing its original structure or content
  3. It has an interactive and user-friendly interface with a quick solution.
