I want to recommend OST to PST Converter Tool which is a powerful tool to convert OST files with all internal elements task, Reminders, Contacts, calendars, alarms, trashed folders, and user-defined folders, etc. The OST to PST software quickly supports all version of MS Outlook 2000, 2003, 2007, 2010, 2013, 2016, 2019 and for the conversion of OST file the installation of MS Outlook is not necessary. A FREE TRIAL pack is available of this tool easily up to 30 emails can be converted into all formats by this demo pack.
More info- OST to PST Converter Tool
OST to PST Converter tool is the best option for repairing OST files and then restore to desired location. It uses advanced algorithms to recover Outlook OST file data from all types of corruption errors. It can save the OST file into multiple formats like PST, RTF, EML, HTML, MSG and PDF. This tool can migrate OST mailbox data directly to Office 365 and Live Exchange mailboxes. To know more about the tool, visit: https://www.datarepairtools.com/ost-to-pst-converter.html
To convert OST to Outlook PST files format then you must download Mailvita OST to PST Converter for Mac tool which easily migrates OST to Outlook PST file format without any size limit and problem. Get the full version of this OST to PST Converter on Mac software to switch entire Outlook OST data in PST format within few seconds. This tool shows all the convertible emails in preview items before saving. I recommend you to first try its free demo version and analyze all features and working of this software.
There are multiple third-party tools available on the internet, you just need to find the right solution. I have used DataVare OST to PST Converter tool when I required the same issue and got the accurate result. The tool works on all Windows versions. A free demo version of this tool is also available few emails can easily be converted into each format.
This tool is my favorite OST to PST converter. It’s free of charge and is one of the most convenient ways of converting OST to PST. It allows you to transfer your files to a new TSP without parting with your money. Read more here - https://emailindetail.com/blog/new-ost-to-pst-converter-free-to-all-users
