Convert the overall data from OST to PST file with the assistance of ATS OST to PST Converter software. Using this application you can easily migrate the data along with emails, draft, task, attachment, calendar, notes, contact (To, Cc, Bcc, From, Date and time). With the assistance of this application you can convert single as well as multiple files.
Through the help of this application you can recover the data from damaged file and then migrate them into new Outlook PST. The application is designed with the best technology and the best technique. During the conversion task it will keep the originality of the database and provide you an accurate result.
It backing MS Outlook version 97, 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019. There is no need to install MS Outlook in your system to convert the OST data into PST file format. Apart from this, it support cloud-based application Office365 & Live Exchange Server that is an additional feature of the application. This setup provides a free demo version which allows you to export 30 emails into PST, EML, EMLX, vCal, vCard, HTML, MSG, MBOX file format.
Read More: https://www.bulkecommerce.com/store/ats-ost-to-pst-converter-software-159.html
