OST to PST 2019 Converter Tool
You can directly save your recovered OST data to cloud-based application Office365 & Live Exchange Server by using the InQuit OST to PST Converter. You can convert your data into various formats like PST, EML, EMLX, MSG, vCal, vCard, and MBOX etc with full accuracy. Before paying the money you can download its free demo version that allows you to convert 30 emails per folder free of cost. If you are not happy with its work so you can return it under 30 days. You can also use this software on different platforms like  Windows OS 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit).
Read More: www.inquitsoftware.com/en/ost-to-pst-converter.html
Try master solution of KDETools for OST to PST Converter software. This is the most excellent answer & great method to transfer the damaged files from OST to PST Outlook format without losing our precise data. Through this software users effortlessly split the large OST files into several parts (25GB).
• Split large PST files into small Parts.
• Filter messages as per the desired date range.
• Supports all files- save Exchange/ IMAP/ Orphan/ Hotmail OST files.
• No need of MS Outlook.
More info- https://www.kdetools.com/how-to/create-ost-to-pst-files.html
