Ost file converter tool
If you want to export OST files to PST format without data loss, you can use OST to PST converter software. You can use this software even if the OST files are damaged. It is an easy-to-use application that requires no prior technical knowledge. Any technical or non-technical user can use this software with ease. You can quickly find master solution name of KDETools OST converter software which smoothly split large size of PST files in small parts of Outlook PST files after conversion OST files database. This is the rightly works to export Emails, mails, and etc. from damaged offline OST files in new Outlook PST file with PST, Zimbra, Gmail, vCard, ICS, office MSG, EML, EMLX, MBOX, PDF, NSF, and etc. file formats.
1- Batch Conversion Option.
2- No OST files size limitation.
3- Selects many items for conversion data.
More info-
ost converter
If you want to convert OST file to Outlook PST, using OST converter tool (DataRepairTools) is the most convenient way. With this tool in a just few clicks, users can easily convert OST file into multiple formats like PST, RTF, EML, HTML, PDF and MSG. It can migrate OST mailbox data directly into Office 365 mailboxes. The tool works well with all versions of MS Outlook and Windows OS. To get detailed information, visit: DataRepairTools
