Only shows MUSIC-can't even check to see if my slot card works! Help!
Just got my SanDisk Sansa Clip 4GB and the Oldies SlotRadio card. My 1st problem is that I charged up my unit & it will only show the Music (headphone) on the screen. I have tried reboot , I can’t even try my card out. Help Please!
There is a protective sticker covering the display that’s hard to see and peel off.  Check to see if that’s the issue.
And to remove the card, you push in again on it to release it. Careful though, or the spring will launch it across the room! :wink:
