OLM to PST Converter Outlook macOS
Microsoft Outlook application for macOS exports all emails, contact, calendars, and other data to an OLM file for backup and migration uses. We have to convert this OLM file to PST file if we want user want to transfer Outlook email database from Mac to Windows Outlook.
vMail OLM to PST Converter is a third-party email conversion tool for mac os, that restores all Outlook mailboxes and other folders in original structure and export to PST file. You can easily import this PST file any latest or older version of MS Outlook for Windows using Import/Export option.
This OLM converter for mac supports all editions of macOS and capable to convert OLM to PST format without any file size limit. There is no risk of data loss with this software.
Read More- OLM to PST Converter for Mac
Export OLM to PST file format with OLM to PST Converter without any error. this software export all emails, contacts, attachments, calendars, sent items, draft, etc. It supports all the Windows and MS Outlook versions. give a try to free demo version to understand working process of the tool. Refer:- http://www.olm.topstconverter.com/
User can convert OLM files to PST files manually for Mac OS and its free of cost. The manual conversion creates an IMAP account with Gmail and then configuring in Outlook for Mac email. With the help of creating label in Gmail, transferring OLM mails to IMAP mailbox which can later on be configured for Outlook on Windows.
The Betavare OLM to PST Exporter tool is the perfect result of your problems. You can export your whole data at the same time, without making any changes. It helps you Export OLM to PST format so that you can access your old mailbox data in the Outlook client. But make sure you first download the demo version for a free evaluation. And if you’re satisfied with the results, then only you should purchase the software.
  1. Launch the Software and it will easily detect the OLM file on its own from the stored location (This software also able to restore data from deleted or corrupted OLM file).
  2. Simply select the mailbox folder and file type of results.
  3. There are many different file formats available for conversion you have to select PST from the given options.
  4. Click on the Convert button and start the Exportation
Visit here:- https://www.betavare.com/olm/pst/
if you want to convert the OLM files to PST then, you can use the best OLM to PST Converter tool which helps you to convert the OLM files into PST easily. It can easily migrate emails, contacts, calendars, notes, tasks, journals, etc. OLM to PST Converter software is export OLM data into a various file format such as EML, MSG, MBOX and EMLX etc. It can convert OLM to Outlook with 100% accuracy without any data loss. This software supports all Windows Operating Systems.
Visit here for more info: https://www.softakensoftware.com/olm-to-pst-converter.html
