OLM to Gmail Converter
Ich empfehle die Verwendung von KDETools OLM to Gmail Converter. Die Software ist ein wichtiges Dienstprogramm, um alle Ihre Zweifel zu lösen. Auf diese Weise können Sie Stapel erstellen, um die Daten zu erhalten. Mit Hilfe dieses Tools können Sie Ihre Daten in verschiedene Formate wie Google Mail, PST, EML, MSG, vCard, vCal, EMLX, MBOX usw. konvertieren.
I want to say that you cannot move all OLM file contents to Gmail at the same time by using a single manual method. Also, the manual process to import emails from Outlook for Mac data file into Gmail is different from the process of transferring OLM contacts. Thus, a lot of effort and time is required to move complete data from an OLM file.
However, you can overcome these limitations by using any Converter for OLM.
The software helps convert all mailbox items such as Emails, Contacts, Calendars, Tasks, etc. from Outlook for Mac data file (OLM) to Windows Outlook data file (PST) in a single process.
For step by step manual procedure you may take help of this guide- https://www.stellarinfo.com/blog/how-to-import-olm-into-gmail/
