# Ok - what am I doing wrong?  SDHC Adaptor does not fit into usb Micromate reader
**URL:** <https://forums.sandisk.com/t/ok-what-am-i-doing-wrong-sdhc-adaptor-does-not-fit-into-usb-micromate-reader/29602>\
**Category:** All other MP3 players\
**Created:** [July 14, 2012, 9:48pm UTC](https://forums.sandisk.com/t/ok-what-am-i-doing-wrong-sdhc-adaptor-does-not-fit-into-usb-micromate-reader/29602 "2012-07-14T21:48:37Z")\
**Posts on this page:** 7\
**Page:** 1
<div class="post-metadata">
**Author:** ![ack150](https://avatars.discourse-cdn.com/v4/letter/a/f19dbf/32.png) [@ack150](https://forums.sandisk.com/u/ack150)\
**Post date:** [July 14, 2012, 9:48pm UTC](https://forums.sandisk.com/t/ok-what-am-i-doing-wrong-sdhc-adaptor-does-not-fit-into-usb-micromate-reader/29602/1 "2012-07-14T21:48:37Z")
</div>
I apologize if this is the wrong forum - I purchased a Fuze+, and with it a Sandisk 32 GB MicroSDHC card. &nbsp;I then bought a Sandisk Adapter to get from the Micro Card to my USB card reader. &nbsp;I then purchased a SanDisk MicroMate reader (SDDR - 117). &nbsp;But the Adapter won’t physically fit into the USB reader. &nbsp;What am I missing?
Thanks!
**Author:** ![saratoga](https://avatars.discourse-cdn.com/v4/letter/s/3d9bf3/32.png) [@saratoga](https://forums.sandisk.com/u/saratoga)\
**Post date:** [July 14, 2012, 10:10pm UTC](https://forums.sandisk.com/t/ok-what-am-i-doing-wrong-sdhc-adaptor-does-not-fit-into-usb-micromate-reader/29602/2 "2012-07-14T22:10:09Z")
</div>
That is a memory stick reader (some stupid Sony format that bombed), not an SD card reader according to Google.
**Author:** ![gwk1967](https://avatars.discourse-cdn.com/v4/letter/g/bc79bd/32.png) [@gwk1967](https://forums.sandisk.com/u/gwk1967)\
**Post date:** [July 14, 2012, 10:11pm UTC](https://forums.sandisk.com/t/ok-what-am-i-doing-wrong-sdhc-adaptor-does-not-fit-into-usb-micromate-reader/29602/3 "2012-07-14T22:11:13Z")
</div>
The SDDR-117 reader is only for Memory Stick (that’s a specific format, not a generic term)&nbsp;cards, not SD cards.
A question: you bought a micro to full-sized SD adapter for “your” USB reader, THEN you bought a reader? Did you already have another reader, then you bought the SDDR-117 (and if so, did that one not work either?), or did you just mean to say you bought the adapter before the USB reader?
**Post date:** [July 14, 2012, 10:18pm UTC](https://forums.sandisk.com/t/ok-what-am-i-doing-wrong-sdhc-adaptor-does-not-fit-into-usb-micromate-reader/29602/4 "2012-07-14T22:18:40Z")
</div>
Thanks to both of you for the response - so the Micromate is the wrong item, got that. &nbsp;But I did have another reader - but given the response, it’s probably for the wrong thing as well - it’s a reader that fits SM/xD memory cards? &nbsp;It’s an old one that worked for my camera memory card (I think the brand it ‘Digital Concepts’). &nbsp;Ok, so what should I be buying, as obviously I’m clueless.
(That was probably obvious from the get go, huh?)
**Post date:** [July 14, 2012, 11:49pm UTC](https://forums.sandisk.com/t/ok-what-am-i-doing-wrong-sdhc-adaptor-does-not-fit-into-usb-micromate-reader/29602/5 "2012-07-14T23:49:17Z")
</div>
Do you even need a SD card reader another? The Fuze+ is itself an SD card reader. If you do want another, pretty much any SDHC card reader from amazon/newegg. The key point being that it supports SD cards 🙂
**Post date:** [July 15, 2012, 1:57pm UTC](https://forums.sandisk.com/t/ok-what-am-i-doing-wrong-sdhc-adaptor-does-not-fit-into-usb-micromate-reader/29602/6 "2012-07-15T13:57:04Z")
</div>
ok - so I can load onto the sdhc card through the Fuze+? &nbsp;I thought you couldn’t do that (was that the old Fuze?) - but if you can, you’re right, another reader is unnecessary. &nbsp;
Thanks!
**Author:** ![tapeworm](https://avatars.discourse-cdn.com/v4/letter/t/ea5d25/32.png) [@tapeworm](https://forums.sandisk.com/u/tapeworm)\
**Post date:** [July 15, 2012, 4:09pm UTC](https://forums.sandisk.com/t/ok-what-am-i-doing-wrong-sdhc-adaptor-does-not-fit-into-usb-micromate-reader/29602/7 "2012-07-15T16:09:33Z")
</div>
> &nbsp;
Not sure where you got that idea. You can load files directly to the card through the player on all Sansa mp3 models (that have a card slot), and have been able to for as long as I know, at least 5 years.
