Please can Vorbis users do the quick test at the end and report results in this thread. I don’t care about MP3, we know it works, just vorbis, flac and others that aren’t the standard MP3.
Ogg Vorbis playback has screwed the pooch. This is also a problem on the Nokia N900 super phone (oops, smart phone / *nix pocket PC)
provided the post isn’t sanitized the following is a bit of research done by someone else:
tuomas.kulve.fi/blog/2009/11/07/n900-battery-duration-ogg-vs-mp3/
Search ‘n900 nokia libvorbis ffmpeg’ under your favourite brand search engine and it should be the first hit.
This is pretty promising as it states that using the libvorbis decoder you lose about 40% battery life, using ffmpegs vorbis decoder you gain about 2% (lets call it equal with mp3 for the sake of argument).
It being promising is based on Sandisk being hoopy froods who really know where their towels are at and get their fingers out, ■■■■ some nourishment, and fix the decoder. And, if that doesn’t make sense, well never mind.
I’ve just done a test against Meat Loaf Bat 1, Bat 2, and the mild insult to Jim Steinman - Bat 3.
Vorbis encoded to 192 VBR (q6)
MP3 encoded to 128 VBR (v5)
MP3 encoded to 192 VBR (v2)
Playing the MP3 128 kb/s tracks (admittedly just the tracks in alphabet order as the playlists & tags were AWOL) I used a whole 2% battery after 9 tracks (~40 mins playback). Taking the units is dead at 50% into account this does actually equate to ~15hr playback (adjust 2% to 4 - 5 % battery use).
Playing the Vorbis back I lose about 2% per track (~6 mins) which comes to around 3 hours (I’m getting about 4.5hrs total playback time in previous straight runs). So this actually tallies. Yep, my whole collection is in vorbis, and I ain’t switching to MP3. Na, ah. They support vorbis on the tin, so they can properly support it in the device.
I already have a complaint / whining about product session open with Sandisk so this will be passed on to them. The tech details of this are also on a battery issue thread.
I’ve had a quick look, but shall provide a proper playtime report on the weekend - right now it’s silly o’clock and I want sleep. Ain’t going to find it, but nothing to stop me wanting.
Please encode a CD or two in ogg and mp3 - preferable both 128 and 192 kb/s for each, however, I’m not exactly in a position to make demands. Completely different CDs between the two formats, although not scientific, will provide some info if that’s what you have.
Play back each format in turn and provide the battery use after ~1hr / 1 CD. Sticking to the following format should make comparison simple.
Format: MP3
DRM: Yes / No (preferable not, but could provide interesting info for drm’d users)
Bit rate:
VBR/CBR:
Time played:
Battery % Before:
Battery % After:
(optionally) album name:
Format: Ogg
Bit rate:
VBR/CBR:
Time played:
Battery % Before:
Battery % After:
Thanks to those who help out here, good and bad results wanted.
