can somebody clear things up for? if i install rockbox BOT rockbox and OF are on the player? only that rockbox once installed is the default choice for the player always ? and i activate (switch) between them if i hold LEFT while booting (back to OF ) ?
and second :
what do i do if the rockbox installer will not work anymore cause files (like the database files and config files) got corrupted or deleted? how do i install/uninstall rockbox now ? is there a manual method as for the OF
