Download the excellent and reliable ATS NSF to PST Converter Software which is eligible to easily recover all lotus notes data from the corrupted NSF file including – emails, appointments, images, journals, address books, drafts and other items.
• Comfortably repairs highly all form of NSF files such that –corrupted/encrypted/inaccessible/damaged files.
• Converts NSF file into multiple formats such as – Outlook PST and MSG, vCard, EMLX, EML, ICS, HTML, CSV. MBOX files and many more.
• Split Oversized or large size lotus notes NSF file into various small resultant PST files as per your needs.
• Exports NSF file data into cloud-storage applications – Office 365 & Live Exchange Server directly.
• All the versions of OS Windows, MS Outlook, and Lotus Notes are supportable in this toolkit.
Bitdataconversion NSF to PST Converter is a well-developed and very well secure software. The impeccable solution of the tool runs without any hurdle to converting single as well as various Lotus Notes NSF data to Outlook PST at the same time without any mistake or data loss. The tool also exports NSF data to EML and MSG formats proficiently. It supports all versions of Lotus Notes, Domino Server, Outlook, and Windows OS. Download Its demo to Convert the first 50 data items per folder.
More details, visit:- Convert NSF to PST
The Betavare NSF to PST Exporter tool can easily export your unlimited files at the same time. You can try the software without any doubt. . It also supports the Windows OS like XP/Vista/10/8 (32 + 64 bit). It easily supports Windows 2003 to the latest versions of Outlook. You can transfer your entire calendar, task, appointments, name, schedule, and etc…You can check your duplicate files while migrating your data.
Visit here:- https://www.betavare.com/nsf/pst/
Download the paramount eSoftTools NSF to PST Converter tool that has been uncommonly made for users need and able to convert over all lotus notes emails into PST Outlook With the assistance of this NSF to PST Conversion Software everyone, can export NSF mailbox data and reestablish NSF to PST, EML, MSG, HTML, and EMLX group alongside emails, contacts, calendars, task, notes, inbox things, outbox things and arrangements. Programming can be straightforwardly introduced on Windows operating systems machines up to 10.
Read More - NSF to PST Converter Freeware
For converting NSF data to Outlook PST, you can use NSF to PST Converter tool. This software migrates all type of emails, contacts, calendars, notes, journals, etc. This NSF to PST Converter tool is able to convert NSF files into multiple file formats like PST, EMLX, MSG, EML, and MBOX formats. Users can download the free demo version for testing the tool and also export the few data items per folder. The software can be used in all new and old version of the Windows Operating System.
Visit here for more info: https://www.softakensoftware.com/lotus-notes-to-outlook-converter.html
