Nsf to pst converter freeware
ATS NSF to PST Converter tool is the best solution to convert nsf files and export emails and other mailbox items from Lotus Notes to MS Outlook PST files. The software converts NSF file to PST file format without any data loss. The software supports all versions of Lotus Notes 9.0.1, 9.0, 8.5, 8.0.2, 7.0, 6.5 and 6.0. Download the demo version from the official website of the converter.
Read More: NSF to PST | NSF Converter | NSF to PST Converter
You can use this NSF to PST Converter tool excellently Converts Lotus Notes NSF files to MS Outlook PST files. With this NSF to PST Converter, all the user mailboxes of Domino Server can be Converted into PST files. The application is workable with all Microsoft Outlook versions. I hope you will get the best results using this software.
More Key Features: NSF to PST Converter
• Instantly Convert NSF to PST format
• More Key Features: NSF to PST Converter
• Shows a free Preview of all converted emails
• Converts multiple format like PST, MSG, EML, MBOX,etc.
• Support all latest versions of MS Outlook and Windows.
• No file size limitation.
• Use Free Trial Version
• Just download the free trial version of NSF to PST Converter software, the free trial version converts few items from each folder.
• You can download this software from here:-NSF to PST Converter
Yes, you can convert multiple Lotus Notes to Outlook PST Conversion by downloading the free trial version of NSF to PST Converter Software. The Lotus Notes mailbox items can be move from NSF to PST. The tool that effortlessly and securely exports to your all type and size data from NSF into, PST, EML, EMLX, MBOX, and MSG file formats. The tool supports all MS Outlook versions like- 2000, 2002, 2003, 2008, 2010, 2013, 2016, and latest 2019.
