I leave my unit disconnected… When I want to do a back up I connect and turn it on… Today when I tried to back up… It appears to not be doing so.It says select content… I select… Then I try to click on the Run Back Up button… Nothing occurs. If I hit the Pause back Up a box appears asking if I want to Stop or continue.I hit continue… Nothing appears to happen… Why is unit not backing up. My last back up worked fine back on 3/5/10.
I am having the exact same problem. It catagorizes files, but then it doesn’t do anything. It says ready to perform backup in the upper left of the screen, but I can’t click Run Back-up, and when I click pause it says its already running. Nothing is happening. I have yellow on my PC side and grey on my drive side, but neither bar is moving and the file count does not change.
