Hello to all of the community ! I’v recently did a long check to my disc and appeared these results. So…should I get ready for a new one ??
Test result : FAIL
Test error code : 08-Unable to repair bad sectors
Thanks in advance !
Test result : FAIL
Thanks in advance !
As the drive failed in test and unable to repair bad sector, It is recommend to take backup of important data files from the drive in order to prevent data loss issues.
I had already made my backup. The question was if this disk can be usable again but the WD Tools in cooperation with windows error checking and Windows Check Disk answered all of my questions since the disk now is not even able to complete even a format.
So…R.I.P. ![]()
| Test Option: | WRITE ZEROS |
| Model Number: | WD 7500AAV External |
| Unit Serial Number: | WCAU40792765 |
| Firmware Number: | 1.65 |
| Capacity: | 750.16 GB |
| SMART Status: | PASS |
| Test Result: | COMPLETE |
| Test Time: | 05:36:34, September 10, 2018 |
| Test Option: | EXTENDED TEST |
| Test Result: | FAIL |
| Test Error Code: | 08-Too many bad sectors detected. |
| Test Time: | 19:22:12, September 10, 2018 |
