Not enough space for music DB - Can't force MSC mode
I recently bought two Sansa C250v2 mp3 players from the Sandisk web site, one for my daughter and one for me. I have macs rather than PCs. I installed a couple dozen songs for my daughter and disconnected the mp3 player from the computer. After physically disconnecting the player from the computer, the player’s screen said it was still connected. I let it sit for a while, but it didn’t change. I held down the power button to turn it off. When I turned it back on, the screen said: Not enough space for music DB- Please free 4 mb. I knew the player wasn’t full so I checked the web site which said an error could cause the problem that might be able to be fixed by connecting to a PC and going through a few steps. Since I don’t have a PC, I figured I’d try again with the second player until I could try fixing the problem with a friend’s PC. I did the same things with the second player and had the same resulting problem.
So next, I took them both to a friend who has a PC. I put the player into forced MSC mode by switching the lock on, holding the rewind button, and connecting it to the PC. Once the computer recognized it in MSC mode, I tried the error correction steps, but the computer told me the error couldn’t be fixed. I then formatted the player and loaded the current firmware, and got it working.
I tried to do the same thing with the second player, but when I try to force this one into MSC mode, nothing happens. Again, I turned the player off, switched the lock on, held down the rewind button and connected it to the PC. I held it for several minutes, but the computer never recognized it like it had with the other player. In this situation, I can’t do anything with it since the computer doesn’t recognize it in the forced MSC mode, and in normal mode I only get the message about needing more space for the music DB.
Has anyone had this problem of not being able to force the player into MSC mode? Any suggestions?
If it worked on one, it should work on the other. I’d contact the SanDisk store about a possible replacement.
If you cannot connect it to Force MSC then more likely it just a C250 V.1. Can you try to turn off the player then put on hold, now instead of pressing the << button, press the RECORD button while connecting it to the computer. See if it will be recognized as 16mb format drive.
You can also try to do the force format on it. While it is off, press and hold the UP button and turn it on. It will ask if you want to format it.
