Not Connecting Help?
I decided to sync a cd onto my Sansa Express, but when I charged it, it wouldn’t show up on the computer.
I plugged it in to various computer.
It shows that it is charging, but it doesn’t show up on any computer.
I tried on a diffrent Windows and on a Mac.
None of them.
Help?
check your mode. if it’s MSC instead of MTP that could be the problem. I had the same issue after updating the firmware and found instructions on this site of how to switch it and now it works great! just search for MTP…
