Ok, there are two Madonna songs I am trying to load. Both are from the same album. I have tried BOTH via syncing w/WMP and Explorer drag and drop (changing modes of course). When I open WMP to view the internal memory, the songs appear AND play. Yet, when I disconnect and look for the songs on the player, they are not there.
I am very confused.
________
It seemed to be a tag thing. However, now the player doesn’t show all of Madonna’s albums under Madonna. I can only seem to find them under albums.
This has turned into frustration now.
________
I just tried to transfer a playlist. It appears that the device is not syncing now.
Should I do a reset? Format?
________
I just did a reset and that seems to have helped. I can now see all of Madonna’s albums under Madonna. Only now, I can’t sync a playlist.
I am content for now. Off to bed…
Oh, thanks for “listening”. However, any help on the playlists is appreciated.
