NOT ABLE TO SAVE .rm FILE on MICRO SD CARD
My Problem is as the player doesnot support real media file i.e. .rm file hence i’m unable to store the music on the sd card. Kindly help me with the way to do so.
Thanks
Put the player in MSC mode and you will be able to STORE the file on the SC card.
But you will NOT be able to PLAY the file still.
Hi Frnd,
This is NOT the solution, what i can do if i’m unable to play the file. If this is the case let me know how to play those files.
What device do you have? The only cards that can play anything other than a .mp3 or .wma (unprotected) is a SDHC card and only a few players have that ability. If you have a E200 of some form, you can only put .mp3 or .wma files on the card, you’ll need to convert the .rm to one of the above
