I am having problems with my express. I have 2 gigs of songs on the SD but when it builds database the Express does not pull those songs off the SD card. Any ideas?
Are you using a 2GB SD card? What I can suggest is that lets try to delete some songs in the card maybe 10 to 20 songs and try it again because the device does a build database because it will read the memory of the card and the memory of the Express, there might be a possibility of a file allocation error. Hope this works. ![]()
