I have a brand new 2TB Studio II with the latest firmware and drive manager. My Mac runs OS X 10.8.2
The drive manager does not show RAID 1 as an option (regardless of whether I connect by Firewire or USB). The drive is now configured as RAID 0; there are no data on it.
I bought the Studio II in order to use it in RAID 1 for my iTunes music library (700GB).
How can I configure my Studio II as RAID 1?
Thank you for your suggestion.
I followed these instructions and now have an earlier release (v 2.2.6) of the drive manager than I had before (2.2.7). It is grayed out and does not do anything. It never installed into the applicartions folder.
Please tell me how to uninstall this piece of software.
http://support.wdc.com/product/download.asp?groupid=114&lang=en
Check the link and also did you updated the firmware of the drive already?
Thank you very much for your prompt and helpful follow-up.
I now have Drive Manager v3.0.1 and used it to configure the drive as Firewire RAID 1.
When I ran the Firmware Updater I received a message to the effect that the firmware on the drive is the same as on the updater.
I really appreciate your assistance.
Would it be prudent to buy a spare drive now just in case they are discontinued? What is the product number?
It should be the same model number of the drive inside the my book studio.
Thanks!
I will proceed according to Section 9 of the Manual and get this information.
