Bonsoir !
My computer was very slow, and I decided to re install it.
I made a back up of my files mon my passport, connected thru USB. I checked that datas were available, I unplugged the disk and start to reinstall.
Later, I came back with my Passport, plug it…and did not get anything. I checked quickly with 2 other computers at home, and got…the same problem.
Pc is running XP, an other one is under vista.
In fact , the system sees the disk (when you use property … or diskmgt.msc.
I tried an other cable, result unchanged
If I do a removal, it’s ok, and then the system says that a disk is connected now…
Datas lost are very important for me, of course…HELP !!
Thanks in advance
JP
An other info : when system sees the wd, it does not get a letter for it ! That’s the point !!!
