No bookmark!
An audiobook player with no bookmark feature is of no use to me. Isn’t it obvious that it is a major inconvenience to have to search for your place in a book every time you navigate away? My fuze+ is going back to bestbuy.
the fuze+ has a resume feature for any file that is stored in the audiobook or podcast folders. when you are playing a file that is stored in the audiobook or podcast folder you can pause it and then listen to other functions of the player or turn the player off. when you come back the the file it will prompt you to resume playing or start from the begining.
You’re right. Thanks. Why did that prompt never come up before you told me about it? Anyway, fuze+ gets another chance.
