we just got a new wifi system. I need to update my passport wireless Pro, but don’t know how
Hi labpainter,
You can refer to the link below to update your WD My Passport Wireless Pro.
https://download.wdc.com/nas/MyPassportWirelessGen2_1.04.17.bin
The steps to update the WD My Passport Wireless Pro are given below.
How to Install the Product Update using the Computer.
-Connect the computer to the My Passport Wireless Pro Wi-Fi network.
-Using a web browser, open the My Passport Wireless Pro dashboard.
For PC, please use http://mypassport or http://192.168.60.1
For Mac, please use http://mypassport.local or http://192.168.60.1
-Go to Firmware Tab.
-Under the Automatic Update section, select Check for Update.
-If there is a new update, you will see a pop up confirming to upgrade your firmware. Click OK.
