Hi Tech Guys,
my brand new MyBook 8TB arrived today (Sunday…cool) and I immediately set about setting it up.
I accidentally connected it in a USB2.0 port because it’s dark where the back of my PC is.
It started up ok and it was available to access.
I set a password for it that I am 100% sure I typed correctly because it is my pc startup password and I typed it twice.
When I tried to copy some files to it I realised I had mistakenly put it into a USB2.0 port. So I unplugged it and put it into a USB 3.0 port.
Of course, it was locked etc so I rebooted the PC with the device disconnected and then connected it again once the PC had restarted.
However, the current situation now is that when I click on WD discovery and it says the device is locked. I click on the device and I type in the password to unlock it and it hangs at this point. The device is not unlocking using the password.
I am wondering if moving the ports from USB2.0 to 3.0 has caused some form of problem and if there is something I need to do to get the device to unlock.
(PS I have an essentials drive and a cloud drive and all my drives in my PC are WD so I really want to add the new Mybook to my WD family of drives here.
Thanks for any tips you can offer here.
Much appreciated!
Best Regards
Peter Nolan
