Got a Fuze, my first. Can anyone help me understand two things not covered in the user manual?
1) There is no button or menu option (as far as I can see) that is the same as the STOP button on a CD, DVD, or similar player. Once I start a track playing, it seems to continue no matter what I do (the scrolling bar at the bottom of the screen says Now Playing…). I use mine for language learning, and frequently need to stop a track in the middle, How do I do that?
2) Can someone actually explain what is really happening when I “sync” my PC (Windows Media Player) with the Fuze? I made some mistakes transferring my first files, and had to delete some tracks and rename some play-lists, and the sync program skipped everything I tried to change. I’d really prefer to copy what I want to the player, and delete it from the PC – don’t care if they are synchronized. (For example, if I am not working on a language, I would take out the card it is on, and put in a different one for another language or for music. I don’t want Sync to delete or change what is on the new card because it deosn’t match what is still on the PC.) It’s obvious that the Sync command is making all sorts of decisions for me, and none of them are explained anywhere.
Thanks in advance to anyone willing to help
