I’m having problems in getting some id3 metafields showing correctly with the new firmware (1.02.26F).
With the previous firmware i used “id3v2.3 + id3v1” tag type and it work perfectly, but with the new firmware it won’t recognize ReplayGain values. So I’ve tried with id3v2.4, but now it won’t recognize Genre metafield value, and with some files will show weird values for Track/Album Gain (e.g., shows -46.44 dB, instead of +3.56 dB. Interestingly -46.44-3.56=-50; or -48.1 dB, instead of +1.90 dB. -48.1-1.90=mmm… ok, ALL mp3’s with Track/Album Gain greater than 0.00dB show “-50.00+realvalue” ). If I play these files with Replaygain ON, volume will be very low (as expected) and it isn’t possible to change the output volume (i.e., output volume is the same whatever position the Volume Slider is in, except in mute, which will mute. I guess, because the gain is too large, volume slider at maximum isn’t enough to bring volume output out of minimum).
I mean, mp3 files with:
-“id3v2.3 + id3v1” and “id3v2.3” tag types, won’t show Replaygain values;
-“id3v2.4 + id3v1” tag types, won’t recognize Genre metafield;
-“id3v2.4” tag types, won’t recognize Genre, Artist, Album and Title metafields;
-ReplayGain values >0.00 dB, will output wrong value.
Also, in Track Info:
-None of them show Year;
-All of them show Track number like xy, where x=TRACKNUMBER and y=TOTALTRACKS metafields;
-Same for Disc number. xy, where x=DISCNUMBER and y=TOTALDISCS.
I tag with foobar2000.
As for Vorbis Comment, works perfectly.
Anyone else have this problem?
Message Edited by eardrum on 04-10-2009 05:10 PM
