I was working in the Command Promtpt and accidentaly launched del *.* on my root folder of My Passport 320 Gb disk and deleted the files - just the files in the root folder. I managed to recover WD Quick Formatter and WD SmartWare files, but need to know if there are other files I should undelete before proceeding using it. Luckilly I have all my files in subfolders.
Hi, nope, you’re good to go.
Thanks for your help Alucardx23. I just wanted to be sure, there is not some obscure hidden file left.
