# Need remote, power supply, A/V cables, and IR emitter
**URL:** <https://forums.sandisk.com/t/need-remote-power-supply-a-v-cables-and-ir-emitter/15710>\
**Category:** Card Readers | Adapters | other products\
**Created:** [August 19, 2010, 8:19pm UTC](https://forums.sandisk.com/t/need-remote-power-supply-a-v-cables-and-ir-emitter/15710 "2010-08-19T20:19:11Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![sully2](https://avatars.discourse-cdn.com/v4/letter/s/8e8cbc/32.png) [@sully2](https://forums.sandisk.com/u/sully2)\
**Post date:** [August 19, 2010, 8:19pm UTC](https://forums.sandisk.com/t/need-remote-power-supply-a-v-cables-and-ir-emitter/15710/1 "2010-08-19T20:19:11Z")
</div>
Hello, I just purchased a V-Mate from Amazon, but it only came with the USB cable and the unit itself. The seller claims she only used it as a card reader and never received all of the “other” things. Well, that makes it pretty useless unless I can find a power supply, remote control, IR emitter, and 2 A/V cables. Does anyone know where I can find these?
I do have a Philips TS1000 Pronto programmable remote if someone has the ccf file they could share with me. I can also “butcher” up a power supply, and I have an IR emitter from an old JVC VCR if someone can tell me if it will work. I also have a 4 pin mini connector to A/V cables from an old video camera, but I would need to know what the pinout is, that V-Mate uses.
I know this sounds like&nbsp; a lot of work, but I was really excited to try this thing, and then it came with all the parts missing!
Thanks for any help.
Richard
**Author:** ![tapeworm](https://avatars.discourse-cdn.com/v4/letter/t/ea5d25/32.png) [@tapeworm](https://forums.sandisk.com/u/tapeworm)\
**Post date:** [August 21, 2010, 5:10pm UTC](https://forums.sandisk.com/t/need-remote-power-supply-a-v-cables-and-ir-emitter/15710/2 "2010-08-21T17:10:35Z")
</div>
You’d probably be better off returning it and buying one from from a ‘real’ dealer, maybe a brick & mortar store. This way you’d get a waranty and you’d have the support of somewhere to return it for any warranty issues or go for any missing parts.
**Post date:** [August 23, 2010, 4:01am UTC](https://forums.sandisk.com/t/need-remote-power-supply-a-v-cables-and-ir-emitter/15710/3 "2010-08-23T04:01:58Z")
</div>
Thanks Tapeworm - that is exactly what I did - returned the unit. Not sure I really need to pursue this device anymore - I really wanted it for the ability to change channels using the IR emitter and schedule timed recordings on my DVR; the recordings on flash memory was just a bonus. Not sure the emitter would have controlled my cable supplied box anyway. I really did want to try it, oh well, I guess it was not to be.
Richard.
