but i found the equalizer…now i just need to know where custom at?
is at the top or the bottom??
can somebody list the order of the options for the equalizer
The Custom EQ setting is at the bottom of all the other pre-set EQ settings. Once you’re there, it’s pretty easy to figure out . . . UP is more, DOWN is less.
Come to think of it, you couldn’t figure this out on your own? It only takes about 1.78 seconds to scroll through the pre-sets and find the Custom setting. Gee, here’s a thought . . . did you even glance at the User’s Guide/Manual (page 22 to be exact). It’s all spelled out in there. Complete with pictures too.
