Need help updating please.
I own V2 Clip running .32
I want .35
When I run updater, it says *service not available*.
When I manually down load the updateand extract to my desktop I get a file that reads *m30pa.bin*
I try and drag to the Sansa folder via windows explorer and it won’t let me.
If I did something wrong, please advise.
Thanks in advance.
Solved
It had somehow switched to auto detect.
Why does it do that on it’s own?
glfnaz wrote:
Solved
Because that’s the default.
And because you updated the firmware.
