If you download dvdvideosofts freestudio software, it really is quite easy to download youtube videos.
Go tp dvdvideosoft.com and click on the “free youtube to ipod and psp converter 3.1”
After downloading, cut and paste that youtube link you posted into the first line (input url).
You also need to put the name of the video in place of the words “from internet 1”(between the slash and the period) on the output line. Otherwise your video will be named “From internet 1”
After freestudio youtube converter converts the file, then you will need to open the file with the Sansa Media Converter, so it can convert the file to something the Fuze can read. SMC will then load it into the Fuze.
I know how to extract the video, I can convert it to every possible format, but SMC wont do anything, it just loads the file, can even play it but displays an empty conversion failure message.
Now, could anyone please convert the video, I’m running short in time…
