Need advice on WD external HD as well as WD Elements Play
I currently have a WD 500GB Black USB 2.0 external HD that I purchased new from WD about 5/6 years ago.
(For the record I’ve never had problems with it and it’s always been a great item for me)
I’ve now filed it up almost to the max. The purpose it uses for me is to store videos. Mainly MPEG, AVI, XVid, MKV, VOB, MP4 & one or two FLV. In time I was to burn these videos to DVD I even spent the money to buy an external burner however as time passed I realized that the amount of time it took for me to restore a file back into my pc, plus the amount of time I spent creating a menu and burning the file to DVD was just too much and I didn’t have the time.
Fast forward to today and now we have several media players out items such as WD Elements Play is something I’ve been doing research on. So here’s what I’m thinking and need advice on.
Would I be able to transfer the files I currently have in my external HD (which I mentioned above) into WD Elements Play? I read the specs on WD Elements Play and I know I can connect an external HD and access files.
I want to be able to view all my videos directly on my TV I no longer want to worry about burning them to DVD.
I ask the above question because I tried connecting my external HD to a HDD Multimedia Player via USB 2.0 and for starters it took a while to load/show that the external HD was connected. Once it connected I opened the first folder which was something like “FAT32” then the next screen it showed several folders with the dates which is how I stored/backed up the videos. I opened those folders and the videos which were suppose to be there weren’t.
I then connected my WD 80GB Passport HD into the HDD Multimedia Player via USB 2.0 and it did show several folders and files which I have in there and the videos played with no problem.
The only reasoning I have behind this is that while the videos in the Passport HD are stored in their original format (in this case AVI) the videos on my WD 500GB HD are stored in a different format which might not be compatible with the HDD Multimedia player. Is my WD 500GB HD just not compatible with HDD Multimedia Players or is there something I missed or need to do?
I was already looking into investing on a new HD since I need space on my Desktop but if I can transfer my videos from my 500GB HD into the Elements Play then I can use that HD that I already have to clear up space on my Desktop.
Thank you in advance for taking the time to read and respond…
If you may want to (in the future)  use Network Sharing / Built in Media Server / Online Services / Mobile Apps etc.
Then i would’nt recommend a " WD Elements Play" as it has None of these features. (No Network Capabilities)
The WDTV Live Hub does  also, Latest model has a 2TB Internal HDD
(i didnt use any of the above features when i 1st purchased my WDTV Live Hub 2 years ago … but now, recently ive bought an Andriod Tablet and can stream all my Media from the WDTV Live Hub to my Tablet … which is pretty cool :smiley:)
Thanks for taking the time to read and reply…
