MyPassport not playing on tv
Hello:
When I plug myPassport into my TV’s usb, I get a message saying:
New portable device connected
Device: MyPassport 0748
Then two options:
Media Play
Software Upgrade.
When I click on either one of those, nothing happens.
Any suggestions? I really appreciate it.  It works on other TVs I have tried.
Thanks!
Have you check if the drive format is fully supported by the TV.
Also make sure that your TV is updated.
