Mybook Live & Web Server Problems
I Bought a My Book Live 1TB External Hard and hook it up to my router, Now I’ve noticed my Apache Web Server is not working keeps trying to connect to WD Hard Driver.
How can I change it so default port is not 80 like my web server or lest get it to play nice with Apache web server maybe something I need to add inside my .Conf file for Apache.
Please if you know anything how to fix this.
I figured it out
The Setting was at “http://WBIP/UI” Then went to Settings and Clicked on Remote Access then for section “Connection Options:” Changed it to manual and there you are able to set the Web Port So i changed mine to 1024.
Then Problem fixed.
