# MYBook for Mac
**URL:** <https://forums.sandisk.com/t/mybook-for-mac/396391>\
**Category:** External SSD for macOS\
**Created:** [February 19, 2010, 4:44am UTC](https://forums.sandisk.com/t/mybook-for-mac/396391 "2010-02-19T04:44:01Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![ptjhr5](https://avatars.discourse-cdn.com/v4/letter/p/a9adbd/32.png) [@ptjhr5](https://forums.sandisk.com/u/ptjhr5)\
**Post date:** [February 19, 2010, 4:44am UTC](https://forums.sandisk.com/t/mybook-for-mac/396391/1 "2010-02-19T04:44:01Z")
</div>
I tried to set up my drive and in the process my dive has disappeared. I can get my cd but not the external drive icon . I work on a macbook pro &nbsp;with time machine. I never got the message acknowledging time machine when I was setting up and now I can no longer do anything. I uninstalled and still have no icon.
**Author:** ![thanarath](https://avatars.discourse-cdn.com/v4/letter/t/b5e925/32.png) [@thanarath](https://forums.sandisk.com/u/thanarath)\
**Post date:** [February 19, 2010, 6:57pm UTC](https://forums.sandisk.com/t/mybook-for-mac/396391/2 "2010-02-19T18:57:58Z")
</div>
If you are planning to use the WD MyBook for Time Machine.
I would suggest you to not install the WD Smartware software.
If you have already installed the WD Smartware, Please uninstall it.
Here is what you need to do:
a. Unplug all power cable and firewire cable from the WD external drive.
b. Restart the MacBook Pro computer. Wait for all icons to show up before move on.
c. Re-plug the firewire cable to the WD external drive.
d. Re-plug the power cable to the WD external drive.
&nbsp;&nbsp;&nbsp;&nbsp; wait a few minute for the drive to be recognized.
&nbsp;&nbsp;&nbsp; Time Machine pops up may show up.
&nbsp;&nbsp;&nbsp;&nbsp; if yes, go ahead say yes to Time machine.
&nbsp;&nbsp;&nbsp; If Time machine is not showing up. You need to re-format the WD external l drive.
&nbsp;&nbsp;&nbsp; Keep the WD external drive plug in.
&nbsp;&nbsp;&nbsp; Go to Go on the apple menu.
&nbsp;&nbsp;&nbsp; Go down to the Utilities.&nbsp;
&nbsp;&nbsp;&nbsp;&nbsp;Select&nbsp; Disk Utility.
&nbsp;&nbsp;&nbsp; Highlight WD MyBook drive
&nbsp;&nbsp;&nbsp; Click on Partition.
&nbsp;&nbsp;&nbsp; Under Volume Scheme click on Current then select 1 Partition.
&nbsp;&nbsp;&nbsp; Click on Options and select GUID Partition Table, then OK to accept it.
&nbsp;&nbsp;&nbsp; Click on Apply.
&nbsp;&nbsp;&nbsp;&nbsp; When it finish, unplug the WD external drive and re-plug it.
&nbsp;&nbsp;&nbsp; The Time machine show pops up and you can use it.
&nbsp;&nbsp;&nbsp;
