I’ve been using mybook duo with ethernet connection to my mac and public folder was my main folder for sharing. Last day something happened and now i cant access to public folder anymore. It says that it isnt a shared folder (although i didnt changed its status) and i cant change sharing anymore. When i open a new shared folder i can see it without a problem but whole my stuff is in the public folder which i cant see inside. Can you help please?
Hi Csrssn,
You should try contacting WD’s Technical Support about this for live assistance and troubleshooting
The link below will allow you to call support
Create a support case with our world-class service and support team.
This text will be blurred
